Watlow Firerod
JoeM1
Jul 2015
Tucson
71
Good Morning,
I am having failures of a Watlow Firerod.
I checked all the basics, (wiring, controls, etc).
Any ideas?
I don't know exactly what you are using or what kind of failures you are having. Having said that , most of my problems with flamerods were caused by poor/intermittent ground path return. To remedy that, I added an additional ground wire between the physical burner and the controller/detector.
Basically what James asked.
Diameter and length of the heater?
Voltage and wattage?
PID or On/Off control?
Are there any obvious signs of failure on the heater?
What color is the heater sheath?
Dark spots or small holes in the sheath?
Guessing this is some sort of internal failure and not leads?
Application? Is the heater inserted into a metal block or liquid?
Is this a new installation, or a proven one that just started experiencing failures?
If so, what if anything has changed between no failures and when the failures started?
Plus what everybody else has asked. Need more details.
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to...
187
Good Eve Gentlemen, We had this cold room which was converted to hot room before I joined this work. Everthing was fine until a month ago, they...
2,135
My system has an Allen Bradley PLC, Red Lion CR3000 HMI, and a Watlow F4T controller. I am able to read registers from the Watlow F4T via Modbus...
1,654
I am sure there are plenty of people here that have used Watlow temperature controllers. We have a thermal chamber that we used to temperature...
3,086
I have a job with two EZ-Zone Ethernet/IP Controllers connected to a CompactLogix L18ERM. I've followed the documentation I could find in setting...
3,769
