Watlow PC31 - Line Alarm
DouglessAtoms
Mar 2024
Phoenix, AZ
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to finalize repairs on this unit.
It's a Watlow PC31-F25B-0000. It's come in with a Line Loss Alarm, blown fuse, and bad SCRs. I replaced all known bad components and have worked my way through a few others under suspicion.
List of repairs done:
- New Fuse
- New SCRs
- New Capacitors and Optocouplers (preventative maintenance)
- New MC14093BDG (gating switch, iirc)
- Unit has both been factory reset and operated with customers parameters.
- I've tried dismissing the alarms/faults, and disabling what might 'detect' them, but this also hasn't worked. (Tried standard, latched, silenced, and silenced and latched.)
After each repair has been done, I've bench tested the unit (120VAC control and ~480VAC line in) and it still gives me the same result: Line Loss Alarm - Line A1.
Good Eve Gentlemen, We had this cold room which was converted to hot room before I joined this work. Everthing was fine until a month ago, they...
2,102
My system has an Allen Bradley PLC, Red Lion CR3000 HMI, and a Watlow F4T controller. I am able to read registers from the Watlow F4T via Modbus...
1,643
I am sure there are plenty of people here that have used Watlow temperature controllers. We have a thermal chamber that we used to temperature...
3,037
Good Morning, I am having failures of a Watlow Firerod. I checked all the basics, (wiring, controls, etc). Any ideas? Thanks
1,795
I have a job with two EZ-Zone Ethernet/IP Controllers connected to a CompactLogix L18ERM. I've followed the documentation I could find in setting...
3,745
