RedLion CR3000 & Watlow F4t
02549117rtl
Dec 2019
California
My system has an Allen Bradley PLC, Red Lion CR3000 HMI, and a Watlow F4T controller.
I am able to read registers from the Watlow F4T via Modbus TCP and the Red Lion is being used as a gateway to get the information into the CIP protocol to get the data to the PLC. I can read registers in the Watlow and send them to the PLC but when I try to write from the PLC to the Watlow it doesnt work.
Has anyone had an issue writing to the F4T?
In the Red Lion I talked with technical support and disabled the 06 function and left the 16 function enabled.
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
881
Action On Release command Set(ConveyorPopup,ConveyorPop_1) rejected w/ string tags. SetStringTag(index, data) wants an index. How does one pass...
993
Looking for the object that will provide entry of an integer value for commanding a setpoint in the DA70A ladder logic. Any ideas?
611
Hi everyone. I worked with RedLion HMI several years, in the last year four CR3000 HMI (10 and 15") had have problems with the touchscreen. All...
1,307
Since the most recent Crimson update of C32-Gold-1016 I seem to have lost the ability to move files on the SD card. I run a background program...
39
