MMC card problem in S7-315 2DP
Iman.
Ignore what Venkata writes.
It is simple, your program that needs 230 kB work memory and 280 kB load memory, can not fit in the 128 kB work memory of you current CPU. Installing a bigger MMC card wont change that. The work memory of an S7 CPU cannot be expanded in any way.
Iman.
Thanks a lot Jesper,
I almost decide to buy a new CPU which has at least 300KB work memory that CPU 317 and 319 has that capacity.But I hope my problem would solve with this decision because it is rather expensive.
One more thing, do you have any idea what parts of program affects work memory??
I think that a 315-2PN/DP will be a better investment than a 317-2DP.
It is less expensive, has enough work memory, and has an ethernet port.
A 319-3PN/DP is overkill for your application.
You can see in the screenshot in post #7 what uses up your work memory.
i am having MMC card(512 kb ) with me. i had format that card with siemens original image & Winhex software. but still PLC is not able to download...
1,580
Hello. I have a problem with MMC 8 MB. After failure while downloading to CPU my memory card was corrupted. STOP blinks on CPU. I tried to format...
2,329
my memory card has been formatted, I'm looking for the image file to use it. Thank you very much 6ES7953-8LF20-0AA0
618
Hi all , In my plant using s7 300 pics . 313C , 315 F 2PN/ DP , 317 F2PN / DP , 315 2PN / DP . All plc used micro memory card . How to take the...
13,073
Hi, I'm new to Siemens and am trying to upgrade the firmware on a S7-315-2 DP CPU from version 2.0.8 to 2.6.11. Appreantly my only option to...
5,019
