How to update S7-315 2 DP Firmware via MMC Card
antsrealm
Dec 2010
Brisbane
207
I'm new to Siemens and am trying to upgrade the firmware on a S7-315-2 DP CPU from version 2.0.8 to 2.6.11.
Appreantly my only option to convert the card into a firmware update card. I have the 4mb card and that's what I am trying to do however I only have a standard card reader and it wont recognize the card in TIA portal 13.
How can I preform this FW update??
If I need a specific Siemens card reader can someone please prepare an image file I can write to the card with this firmware update file on it. I have the clean image to restore the card if necessary.
Thanks,
Yeah thats what i thought. Is anyone with that tool able to quickly create a card with the firmware update on it then image ot with winhex or hdd raw copy and ill write the image to my card and give that a go.
I assume that will work?
Thanks.
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
107
Has anyone found a way to convert/replace/update the firmware on old Parker TS80xx series HMIs (i.e. TS8010, TS8006, etc) to accept Crimson...
91
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
89
Hi, I have an iFIX 5.5 project (Windows 7) that needs to be updated to version 6.5 (Windows 10). iFIX communicates with the "Siemens Industrial...
173
Hi I have a number of the older PanelView Plus 600 HMI's (2711P-T6C20D, Ser D) that I want to update to the latest firmware. I believe that the...
463
