Testing Allen Bradley Point IO unit
razmis
Mar 2017
Hadera
26
I want to test a small cabinet that includes a POINT IO unit type 1734-AENT.
How can I test this unit if I don't have a PLC?
You can browse the backplane of the 1734-AENT assembly using RSLinx Classic software to be sure that it is detecting all the attached modules correctly, and you can check the basic functionality of many input modules by observing the status LEDs on each module.
But to test it for sure, or to test output modules, you will very likely need a ControlLogix or CompactLogix controller.
If you are feeling adventurous, and time permitting, there is an Ignition SCADA E/IP driver that can talk to Point without the need for a physical PLC. It can be downloaded from their forums.
It also should have a built in web server so if it is on a network you should be able to access it via web browser. Just type the IP address of your 1734-AENT module.
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
123
Hi all, I have a AC current transducer that I want to bench test to ensure I am getting a 4-20mA output. I am using a AE001 unit. It is very...
129
Hi Guys, Can ControlLogix with Modsim32 for Modbus Server Testing? I have ControlLogix via Anybus Modbus TCP and I need to Test the...
342
Hello all, looking for ideas on getting some basic training done, I need to practice on maintenance timers and bypass switches (with a Factory...
1,331
I have a project in FTV ME (Studio v13) that I'm trying to apply security to a few buttons/setpoints. I have 4 users: Anonymous Logon, DEFAULT...
797
