ControlLogix with Modsim32 for Modbus Server Testing
Chibu
Feb 2023
Ontario
49
Hi Guys,
Can ControlLogix with Modsim32 for Modbus Server Testing?
I have ControlLogix via Anybus Modbus TCP and I need to Test the configuration.
Any ideas will be appreciated.
I tried it, I was able to write from controllogix to Modbus Server Simulator only twice and it never worked again even with restarts/reconnection of the Demo
I alternate modsim with the modRSsim2 here, it is free:
https://sourceforge.net/projects/modrssim2/
I like modRSsim when I just need a quick set of registers, it takes less time to configure. I have found that in Serial situations, where a person might want to have a mix of Real nodes and a simulated node, this simulator will not play nice. It really wants to be the only serial node on a chain/line.
TCP works fine.
82
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
103
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
231
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
214
Trying to setup a message read via Ethernet. I have the path setup as 1, 1, 2, 192.168.66.10 I get an error code 1, ext err 315. I am beating...
253
