Sinamics S120 DDC Winder Application Note A4027118-A0461
JRW
Jun 2002
South Carolina
2,306
I'm getting ready to implement the standard winder
A4027118-A0461 application note from Siemens. This uses Drive Control Chart.​
Have any of you Sinamics DCC users tried this app. note?​
If so, any oddities? or tips?​
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
966
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,140
We have a couple of S120 drives which are rack pinion system,which moves forward and back ward (linear motion only) . The drive shows Fault 7900 3...
19
4,352
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,427
I have a master slave setup for speed control.. I used the encoder speed unsmoothed from the master to the slaves.. It is a speed control...
1,479
