Sinamics S120 Questions
plcengineer
Jan 2004
USA
176
I have a master slave setup for speed control.. I used the encoder speed unsmoothed from the master to the slaves.. It is a speed control application and it doesn't require load sharing.. The slave runs a ratio to the master..
Do I need to send a torque setpoint even though I need speed control?
Should I put a filter of 1ms on the encoder feedback to send to the slaves.. Or, is there another tag I should send to the slaves for the master speed reference?
I went through all the tuning and speed optimization.. I see a 3-5 RPM variation on the reference.. Is that normal? What is the best way to tighten up the speed control? I thought it would be closer with all the tuning I did but maybe it needs manual attention?
I seen different choices of setup in the starter software.. I have mine setup now for a speed control with encoder. I noticed many choices and one of them said something about precise speed control for textile? Not sure if any of those choices would help tighten things up..
Would the extended ramp generator with setpoint tracking help? I do have the ramp generator on and I have my ACC 3 sec and my DEC 4 sec.. I read that with the setpoint tracking, you can enter the delta speed value to maintain? I think it was P1148
Thanks,
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
957
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,133
We have a couple of S120 drives which are rack pinion system,which moves forward and back ward (linear motion only) . The drive shows Fault 7900 3...
19
4,344
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,420
We are installing new S120 drives on a R&D machine.. we will have a master drive with multiple slaves.. The slaves will follow the master line...
2,401
