Panelview touch not working. Allen Bradley 6176m-17pt series c
hbelec4
Mar 2024
victoria
Hi
Having issues with a older PanelView touch not working.
Screen is connected to a Desktop computer. screen used as a display with touch.
Downloaded Driver updates etc via Rockwell for the panel view, no luck.
running Egalaxtouch also with the most updated driver.
Anyone able to help? would be much appreciated
Panelview Allen Bradley 6176m-17pt series c
Did it used to work on that PC? If so, I would first suspect something failed inside the unit or an OS update broke a driver.
Which driver did you end up using? We replace a couple of old units with 6176M-15PT models. There were 2 different driver packages:
6186M_6176M_Touch_EETI_XP_5.11.29.9628
eGalaxTouch_5.14.0.15315
What OS is on the PC? Ours were on older XP systems so we used the first driver which installed and ran smoothly. I'm assuming you're running a newer OS and needed the eGalaxTouch driver. I'm afraid I can't help you much with that one.
When we had the original screen fail on a newer machine, the 6176M was discontinued so we used an Exor unit instead. That turned into a battle as well, but that's a different saga...
Hello, I have 2 PanelView+ 1500s and the touch screen freezes up from time to time. Sometimes it will for a few days then other times it will do...
1,604
I've had to do a considerable amount of "squashing" on some PanelView 1500 display screens, that I'm now concerned the touch areas are too close...
2,739
Hi all, I am totally new when it comes to anything with PLCs, so please excuse my ignorance. We recently had our PanelView+ 1000...
1,587
I have some operators that are asking (begging) to make the main screen display list selector a touch object. I didn't think it was possible...
1,730
Hi all! I'm trying to restart an HMI which originally showed the message 3a Stuck Touch. I cleaned the HMI, then rebooted it, it now show a...
6,357
