Stylus for PanelView Touch... ?
daba
Jul 2004
uk
5,401
I've had to do a considerable amount of "squashing" on some PanelView 1500 display screens, that I'm now concerned the touch areas are too close together for Bubba's fingers... There's no overlaps, but there's only a few pixels between buttons.
Has anyone used a stylus with the PV ?
What's the best type ?
Longevity ?
My client will accept a stylus solution, as they don't want the expense of replacing the HMI with a more modern unit that can do higher resolution than a PV.
Yup, we do similar thing, tie a pencil on a string. You can probably get specialized stylus.
Keep in mind, that panelview and other industrial touchscreen are resistive so only pressure is needed so any pointy object can work.
Yes, I use a stylus all the time on Panel View screens and almost any resistive touch screen, I buy ink pens with a pressure type stylus on the non writing end so I always have one with me. I'm sure a pencil eraser would work just fine, but I work in the food industry so pencils are not allowed on the floor.
But pens with ink in are allowed ???
I've adjusted the IP of the Panelview Plus as well as the DNS servers; the screen does not show up in the search when I go to the transfer utility...
109
Replaced overlay and glass in HMI but now I can not calibrate the touch screen any suggestions.
84
i have 2 backups: *.PVC and *.pvd file types thanks in advance for any help
162
I'm at a loss here and hoping someone else has seen this: Background: We've got two identical machines on our floor (we'll call them machine A &...
90
146
