harrione300
Ok, I have a micrologic 1200 plc that I'm tring to get to communicate with a panelview 300. It has a 1761-cbl-pm02-ser.C cable that plugs into the plc and then on the other end it has a 9 pin female d shell connector. Then there is a short patch cable-9 pin d shell male on one end and female on the other end that plugs directly into the panelview. The problem is that the female end got cut off and is gone and we just keep getting an error message about no nodes found, the same as if there is no cable hooked up at all. does anyone know the wire locations for the female end that plugs into the panelview. Panelview is a 2711-K3A5L1 24vdc
