Adding Produced and Consumed Tags with redundant 1756-L71 controllers
johnplatt55
Jan 2016
Minnesota
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other compact logix PLCs and all of that works great. I am adding a 4th CompactLogix 1769-L30ER plc and need to utilize a few produced and consumed tags between it and the redundant pair previously mentioned. Is it possible to take one of the pair of L71 controllers offline and add the needed produced and consumed tags and have it sync the changes to the online controller? The whole point of redundancy was intended to limit any possible downtime, it seems there should be a way to keep running and add these tags but i've come up empty with the redundancy controllers manual and the produced and consumed tags manual.
Any insights would be greatly appreciated
Thanks,
JP
I know of no way to add produced / consumed tags without a download, be it redundant or non-redundant.
Syncing a running controller program to incorporate changes in a offline program would be a heck of a trick, does any mfg-controller support that?
Hi, I need help adding a new interlock switch to an existing circuit. I have never done on the existing circuit. I did set it up on the...
279
Hi all I’m looking at adding a RFID card reader to comfort panel pro , how do you set the rfid up can you connect to existing users and password...
94
Hello all! So I have one project with a S7-1214 and a MTP1500 "Project1" and one project with another S7-1214 "Project2". Both of these PLC:s need...
150
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
122
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
201
