Adding Produced and Consumed Tags with redundant 1756-L71 controllers
johnplatt55
Jan 2016
Minnesota
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other compact logix PLCs and all of that works great. I am adding a 4th CompactLogix 1769-L30ER plc and need to utilize a few produced and consumed tags between it and the redundant pair previously mentioned. Is it possible to take one of the pair of L71 controllers offline and add the needed produced and consumed tags and have it sync the changes to the online controller? The whole point of redundancy was intended to limit any possible downtime, it seems there should be a way to keep running and add these tags but i've come up empty with the redundancy controllers manual and the produced and consumed tags manual.
Any insights would be greatly appreciated
Thanks,
JP
I know of no way to add produced / consumed tags without a download, be it redundant or non-redundant.
Syncing a running controller program to incorporate changes in a offline program would be a heck of a trick, does any mfg-controller support that?
Hi Everyone, Currently we have three plants running with Controllogix PLCs (L72, L73, L74). In each of these plants we have 2 FTView SE...
57
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
136
I'm adding an IAI Gateway with 2 axes connected to it. To an ethernet network on my PLC. So, I think the math is correct on the Input and Output...
148
Hi Folks. I am gearing up to add a 2nd identical HMI to a project. This 2nd HMI will basically be an exact clone of the 1st one. The equipment...
264
Hello all, I have been tasked with flashing our processors to the newest version of Studio 5000, and have downloaded the DMK file for the...
242
