1734-aent connection problem
What version of RSLinx Classic are you running ?
It's possible that your version of the software never had the version of the applet that supports the tab that lets you set the -AENT/A chassis size.
Because you're running a computer that's running SoftLogix 5800 you should be careful with your upgrades and installations. This is one of the reasons I keep asking for revision numbers.
Or maybe your 1734-AENT is so very old that it doesn't support the features that all the others did, and you'll have to use RSLogix 5000 or the web browser to configure it.
At this point it might be best to uninstall your 1734-AENT and take it to an A-B distributor and have one of their specialists reconfigure it for you. I would have done that for any customer who walked in the door.
Are you possibly not doing a right click on the actual AENT in RSLinx?
Compare Ken’s picture and yours, Ken’s shows the AENT with IP address highlighted, yours shows the AB_ETHIP-1 driver highlighted.
Open your RsLinx Classics > can u see your aent > right click > device properties > set a stactic ip.
your IP is getting removed when poweroff.
Hi friends, can anyone please explain to me what is the difference in setting up the Point I/O as Rack Optimized or Direct Connection. From what I...
5,088
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
790
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,524
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,427
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,648
