1734-AENT Rack optimized or Direct Connection
Adam303
Aug 2009
Chicago
587
Hi friends, can anyone please explain to me what is the difference in setting up the Point I/O as Rack Optimized or Direct Connection. From what I understand in the manual those two only differ by use of RPI, but I wanted to know if there is anything else that I might be missing.
Thank You
Rack Optimized grabs all the discrete module data for the whole FLEX adapter in one packet.
Individual Module connections grab only one module at a time.
Use Module connections for Diagnostic discrete modules, for Specialty modules, and for Analog modules.
The only time I've used a Module connection to an ordinary discrete module is when I had one relatively fast DC module in a rack with a bunch of slow AC modules. The one module got a fast 5 ms RPI and the rest poked along at 50 ms in the Rack Optimized connection.
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
792
Hi All, Have got a problem which i first thought to be a network problem but now starting to think we have got a broken 1734-AENT PointIO unit...
29
4,529
Hello. My facility has Point IO modules (on a separate cabinet) which is connected to a controllogix PLC via 1756-EN2T module. We lost...
1,437
Hello, There is a small test rig in our work which is sometimes salvaged for parts. The test rig is connected to a small robot used for training...
1,651
I had a 1734-AENT point IO adapter go bad. It was a series A F/W 3.006 I order a replacement, however it was a 1734-AENT series A F/W 1.033 I...
2,088
