Uploading new program ML1400
djeims
Sep 2014
Keflavik
Hi guys,
I can't quite figure out how to upload a new program to the ML1400 that I'm working with. Every time I try to upload a code I've been editing in RSLogix 500, the ladder is replaced with the program previously loaded on the PLC.
Does anyone here have experience with Allen-Bradley products?
Regards,
David
David,
Your terminology is incorrect.
If you have a program in your PC, to get that program into the PLC you must perform a download.
If you have a program in your PLC, to get that program into your PC you must perform an upload.
To sum up.
PC to PLC - Download
PLC to PC - Upload.
Hope this helps.
Cheers
Mark
David,
To sum up.
PLC to PC - Upload.
Hope this helps.
Cheers
Mark
Upload means to get the program OUT of the PLC.
Download means put your program INTO the PLC.
Alan
Wow, I feel like an idiot now. That clears everything up for me though.
Thank you Alan and Mark!
Regards,
David
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
197
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,392
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
718
Hello im hoping someone can point me in the right direction. I have a SLC-500 that the program has been erased. I'm being told it will require an...
1,548
Hi dears I am facing problem during program upload on S7 200 (226 cpu)microwin 4 sp9 closes on 100% I try to upload data blocks, its ok, System...
2,464
