Uploading program from Siemens PLC via CP 343-1
yam
Mar 2024
Dubai
Hi everyone,
I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU has none.
They are connected in 1 Rack, CPU slot 02/03 and CP is slot 4.
The IP address for the CPU will not be shown since it has no LAN connections, only Profibus cable.
I am receiving an error "Downloading the configuration is only possible via a CPU...." The only address showing is the CP.
I am sure that it is possible to do a backup from CP on this case because I have done it before. But I can't remember because I was too occupied to resolve the issue.
I have tried using MPI cable as well, but I am receiving error message, "Online: The local MPI address for the programming device/PC is higher than the maximum node address or the wrong transmission rate or wrong interrupt is set." Address is set to 0 and transmission rate is 185kbs.
Kindly help to resolve both connection issues. Thank you
this thread should help you
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,892
Hello All, I am using siemens s7 200, CPU 224N. The problem is PLC has program but when i am uploading it, everything goes successful but the...
4,056
I am looking to upload a program from a siemens plc program, and as I am not the most experienced at this i was wondering where i could find a...
4,445
hi folks! can somebody please help me with my problem. I want to upload the program from siemens plc 115u to my computer using s5 (v7.2). then...
9,486
Hey, i'm getting an error when i try to upload a program from a modicon M258 TM258LF42DT using eithernet. i tried using both SoMachine V4.1 and...
1,379
