Upgrading RSLogix 5000
sparkytex
Jun 2013
Port Hardy B.C.
354
Hey everyone,
Does anyone have any tips or suggestions on how to go about upgrading RSLogix 5000? For example upgrading from v17 to v20 with the same license. Do you call Rockwell to do this and does it cost money to upgrade?
Thanks in advance,
- Tex
as long as you have a license you can upgrade the firmware, software from there website.
I think some processors have compatibility issues with some hardware so research this before upgrading.
There is a compatibility matrix that can provide this info on the website.
If you do upgrading of firmware and software. I do not think it would cost you a thing except a headache of an experience.
Remember always do backups before you do the upgrade. You can always go back if you know how. Most firmware will let you go backwards up to a point. Know where these limits are too.
If you have a spare processor available, my preference is always to put the new firmware on the spare, load the program and then swap the processor. Much quicker going back if you need to. This approach works fine as long as there aren't other pieces of equipment that also need firmware updates... in that case, being able to do one of each device on the bench so you have the process ironed out is very valuable.
As Jim said, doing your homework before hand to check firmware compatibility is a must.
As long as you have the software license details you can download any version up to the version you purchased. Maintaining a techConnect contract is generally a requirement to be able to access all the newest versions
This is all correct except you will not have access to any newer versions than the one purchased unless you have a TechConnect contact with that serial number. This only applies to the Rockwell download / installer. If you have access to a v20 installer, then you will be able to install the updated version and it will activate.
I have a client that has RSLogix 500 v4.3 Standard & RSLinx v2.3 Professional. I need to upgrade their RSLogix 500 to v 8.1 standard because they...
13,845
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
431
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
553
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style. currently we have 4 1394 axis that are all driven by 5kw...
890
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,127
