Upgrading 1394 Digital Servo Drive to Kinetix 5700
Drewster1123
Nov 2022
Ontario
31
I am looking to upgrade some of our old Servo Drives to the newer kinetix 5700 style.
currently we have 4 1394 axis that are all driven by 5kw invertors.
I was looking through the kinetix user manual and found a dual axis 5.5 kw invertor that I think would be suitable. Part #2198-D020-ERS3. Two of these drives combined with a regenerative power supply part#2198-RP088.
This will also need to be setup in the PLC program but we have 4 other drives that are already on the kinetix 5700 platform so i know it is compatable.
I also know I will need to get proper size fuses for the new drives and get a PSR when all is said and done.
Is there anything I am missing?
Thanks in advance.
Your motion specialist at the AB distributor will get you everything needed. Power supply to axis will require busbar connectors. Some axis drives will require a special plug to convert encoder singals.
This power supply will also require eithernet connection and setup in the PLC, it's not like the old "dumb" power supplies.
I have the new servos up and communicating. Will the tag names in the motion group be the same or are there new tag names associated with the new...
1,960
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
482
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
574
Hello, We are currently running a bunch of g310's connected to their SLC5 PLCs through ethernet. I've attempted to upgrade the program from 2.0...
1,152
Hello everyone, My company has an old line for building DC motors. Many machines are from the early 90's and some requests for safety...
1,170
