Studio5000 AOI Default Values
timryder
Feb 2007
Macomb MI
176
Hi guys,
Making a bunch of AOI's for company and I was wondering if there was a way to make them pre-populate their input requirements with the Default value they were created with. As of now when I drop the AOI on the ladder it shows up with a bunch of ?? and not say the DINT value of 50 for one of the variables I set. Is there a way to do this?
Looks like under the Parameters tab when you create the AOI, one of the columns is Default, not sure if that answers your question or not.
EDIT: Mine also show "??" until I actually create the AOI tag
EDIT 2: I also see that you already mentioned the Default value, do the question marks change to the values if you create the tag for the AOI?
LoL thanks anyways. Yes I did see that column and did populate them with values. I just do not see how to Activate those values by default like it would say if I added a motion instruction on to the ladder. Those come pre-populated with their respective default values.
If anyone knows how, I would sure appreciate the tip!
UPDATE: I figured it out,
Kinda....
By unchecking the "Required" flag on the AOI configuration page, that for some reason made them populate on the Ladder with their respective Defaults.
The whole purpose of the 'Required' flag is to force external data to be used. To quote the manual, "To help be sure that specific data is passed into the Add-On Instruction, you can use required parameters. A required parameter must be passed each argument for a call to the instruction to verify."
Since it will be using data from an external source, there's no sense in populating with the internal default it won't be using.
Not sure what that didn't click yesterday, but today it seems like a "DuH!"
Thanks for the manual snippet. Makes sense.
Hi Hope you all are doing well. Iam working on a project with some AOI. I also hate no online edits... lol. My problem occurs when I use a UDT...
202
Existing environment shown in attached photo (Existing.jpeg) Proposed Environment shown in attached photo (New.jpeg) I am migrating a PLC5 system...
610
I am curious why my latches do not work and maybe someone here has some insight. I have created two AOIs. One AOI latches an output on (ON)...
1,825
Hi, just wondering if anyone has made an AOI that would generate a permissive from a selectable number of true inputs from say 8 discrete inputs...
1,103
Hi all one question about Logix5000 and AOI: normally I work with Siemens, and I use FBs with multi-instances Now I need to transpose the...
2,730
