Studio 5000, Modbus (eth-rs232), Metro M400 air gage
Jun 2023
Ohio
Hello,
I been trying to pull the probe readings from my Metro M400 air gages through a modbus to a plc. I have a connection right now between the plc and metro, but I can't get any readings from it. The connection sts_overlap error pops on and then the sts_overload comes on after that. I'm not sure how to remedy this problem, but any insight would help?
[url]https://ibb.co/gjYch22[/url]
[url]https://ibb.co/bKrCZ4w[/url]
[url]https://ibb.co/dBspcx8[/url]
[url]https://ibb.co/PCNTnTs[/url]
[url]https://ibb.co/yV14VCT[/url]
You might get a little bit better response if you provided some details about the application. For example, Studio 5000 is programming software, not a PLC. What PLC are you using? What is bridging the serial protocol (I’m assuming Modbus RTU) to EtherNet/IP? Right now your question is very vague, if anyone is going to be able to help you they are going to need details and they are going to need to see what you have tried so far.
So I am working on a project and I am having problems trying to get this all to work. I had it working but lately I have been getting a fault on...
4,872
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
310
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
382
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
130
