Studio 5000 - a newer version of Catalog Services is already installed
Oct 2020
Saltillo
Hi, Im trying to install Studio 5000 V32. I've installed the previous version in order from v20 to v31.
Whenever I run the setup file i got this. I've already try to install just the Logix designer V32 instead of everthing else but is the same issue.
Anyone have had this issue before and how did you fix it?
Search for "Rockwell Automation Catalog Services" in the windows registry. It should be found in a directory with a long random looking string name, in HKEY_Classes_Root\Installer\Products. For example, this directory on my machine is named 5F21E316AB3685E46896E1B1093A19FB. Export it to save a copy of it, just in case. Then delete it.
My issue with the "Install Older First" is that Rockwell has never published a list of orders.
Remember v20.05 is newer than v26, and I think v29 also. So installing 20 before 26 is out of order and will install newer packages earlier.
I even asked Rockwell Tech Supp once and he wasn't sure of the order.
I just got off the phone with Rockwell. I had an install fail. They got online with a webex session and uninstalled a couple of things installed (I forget the exact names) related to logix 5000. Then the catalog services was able to install which is what was causing the failure.
To the OP-did you get this resolved?
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
298
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
127
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
79
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
208
