Step 7: MicroWin to Simatic
Cryogen
Oct 2005
NH
151
Hi Experts!
I have good experience with the Siemens Step7 Microwin (programming a lot of S7-200 PLCs). I am now trying to program a ET200S with the Step7 - Simatic. I have little experience with it. So please help me, I have couple of questions:
1. How do you program logic that operates only for the first scan? I see OB101 or so for it but wondering which one to use - Warm start, Cold, Hot.. Also, is there a "Always_On" system bit?
2. Is there something similar to a V memory? I see M memory but looks like it can be used only for 256 bytes. Do I need to use DBs for it?
3. Also, if I need to update the program to another ET200S, can I just move the memory card?
Thanks.
This you can do using M bits.U need set the M bit after job is done and then make sure that logic is not executed as long as M bit is set.
-->Same as above you can make Always On bit and that you can do in OB1.
AN M0.0
SET M0.0
-->DB are equivalent to V memory
-->moving MMC to ET200S!!What that mean, how does ur CPU talk with ET200s. Is it IM151-1 or IM151-3 PN?
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
267
Hi, I recently got a laptop to install Step 7 MicroWIN on, its a Windows 7 laptop 64-bit. I have moved the .exe files for the full installation...
4,702
Hallo to everybody, I'm new in this forum and i would like to do some questions about siemens plcs. First of all i would like to program the...
4,015
Where i can download microwin 4.0 sp3 package for S7-200 CN siemens PLC..
4,135
Hello to all I AM Ruel A new PLC student her in the Philippines can some one give me an example how to convert from MWP file to AWL file, this is...
3,208
