Simatic S7 300 And Win Cc 6.2
vikas.vvs
Apr 2007
sharjah
25
Dear All
I Am Trying To Connect A Simens Simatic Plc (s7 200 Cpu 313c) With Wincc Software . Please Help Me To Configure This
To Connect The Plc And Software I Should Use Which Cable? (mpi/pc ??)
Then How To Write Code I Dont Know??
And Controling The Tags
Please Help Me
Vikas
Hello vikas.vss;
First, may I suggest the following manual: "WinCC v.6.0 getting started"; you can find it in the following webpage:
http://support.automation.siemens.com/WW/llisapi.dll?query=WinCC+getting+started+manual&func=cslib.cssearch&content=skm%2Fmain.asp&lang=en&siteid=cseus&objaction=cssearch&searchinprim=0&nodeid0=4000024
In WinCC you set up the connection between the WinCC tags and the PLC in the "Tag Management" editor; in a new installation, you will find only Internal Tags; install a new driver (the S7 Protocol suite installs drivers for MPI, Profibus ans Industrial Ethernet); you will need a Simatic net card (CP5611 or CP5613 for MPI/Profibus; CP1613 or a regular NIC for Ethernet) and the adequate Simatic Net driver on your computer to establish connection with the PLC. Selecting the card+driver will also help you select the cable you will need. We can give you more info if you tell us what network you plan to use.
Once the driver is established in Tag management, you can start creating new tags (the Getting Started manual has examples). You can also import them from Step 7. If you use the Graphics Designer to create a screen, place any object that can be animated, you can link its properties to tags that you created in Tag Management. For example, the colour property of a circle can be made dynamic based on the status of a Boolean tag you created.
Once you have studied the Getting Started manual, you will find many more informative manuals on the link mentionned above.
Hope this helps,
Daniel Charier
Hello vikas.vss;
I will try as per your instructions
I would much rather have you try with the instructions from the manuals. My suggestions are very sketchy, based on very little information and might cause many more questions that are answered in better form in those manuals.
Hope this helps,
Daniel Chartier
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
188
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
323
How can I integrate my S7-300 Simatic with the IFM AS-i Master AC1335 and its slave IOs, such as 2411 and Airbox 2041, into Simatic Manager?
151
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
771
Hi to all, Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic...
1,083
