Help with IP address on a Siemens Simatic S7300
Feb 2007
Oklahoma
277
Hi to all,
Our company does not usually use Siemens PLCs, but have a press with one in it. We are trying to change the IP address in our Simatic S7300. Thank you all for your help.
If the PLC is not password protected, then you can upload the program with Siemens Step7 V5 or TIA V11+ software. The software version must be the same with which the program was made.
You can then modify the IP address and download the modified HW configuration.
Big warning though: Changing the HW configuration that is from someone else can have unknown consequences. There are also plenty of changes to mess things seriously up if you are not very well versed in Siemens S7.
Depending on what you want to achieve, maybe a 1-to-1 NAT can solve your problem without needing to change the PLC program.
Hi all, I need to find all the IP address on my Plant network. Rslinx shows me only Rockwell devices. I tried arp -a , same as Rslinx. It does...
3,068
I have a PLC5/40E that I need to change the IP address of. I have changed it multiple times and it keeps returning to the original address. I...
1,925
Hi all, I'm not all that clued up on GX Developer with A series CPU. I have an Ethernet module A1SJ71E71N3-T and for the life of me I cant...
1,419
Hi everyone.... I need your help, I don't know what is the IP address from my Allen Bradley Micro820, has a fault and I need go online to check...
18
10,930
Hi All, I am new to PLC, i am using Allen Bradley. My issue here is that one of the company's old coworkers setup an ip address for the plc but...
2,324
