signal 4-20ma in plc
How do you know it’s noise?
The simple stuff is:
Shielded, twisted pair with the shield only connected at one end.
Don’t run analog with or parallel to power runs.
Cross power lines at right angles.
Sometimes if you hang a capacitor across the input terminals it will attenuate the noise. Try a 220 micro-Farad and see if it works.
Hi; I have installed a temperature and humidity sensor Autonics THD-R-C which gives 4-20mA signal out. The signal is connected with Fatek...
2,778
Hello, first post here and have a puzzling issue. I have recently been troubleshooting a PLC for a client that gets a 4-20mA (24VDC) signal from...
21
6,553
I'm trying to hijack a laser's analog signal from a Modicon to a CLX5000. I ran the wires and did the hook up as normal parallelling in with the...
17,519
Can someone help? I have AB L32E with a OF4CI analog output card and need to send a 4-20ma signal to another guys PLC with an analog input card...
8,721
Hey folks, I have a situation where I need to connect a 4-20mA transmitter to an AI card that only does 0-20mA. On top of that it only has 8 bit...
2,442
