S7300 plc + cp343-1 lean -> wago
boneless
Feb 2008
OKC
1,628
Hi all,
I am tasked with quoting a solution in which our two S7300 PLC's with added 343-1 LEAN CP is supposed to communicate with two WAGO IPC 758.
My client is assuring me that we can use Modbus TCP, so I am looking into that. I have found the examples and I think I found the correct license. Can somebody confirm my item number?
2XV9450-1MB00
S7 - OPEN MODBUS/TCP FOR NCM_CP, SINGLE LICENSE, ON CD
As said, we have two PLC's with each a CP, both are communcating with the same two WAGO PLC's. I am assuming we are the SLAVES. This means each CP has two connections.
Do I need 2 or 4 licenses?
Is it possible to buy this digitally? We would need this rather sooner than later...
Wago has a library called s7 db read which allows you to read and write directly to a data block in a siemens cpu. No orogramming required at the siemens cpu.
I have used it with the newer ethernet controller. 750-8xx series.
It might work with your ipc. Worth trying as the license for the siemens modbus fb is too expensive.
Hi again Rohan,
Just wanted to let you know it works great! You saved my client about 5000 euro's and me a big head ache!
If you are ever in Oklahoma, let me know, I owe you a beer or two! :)
Where can i find this library for wago plcs?! Thank you!
Hi Any one here please helpmein simulation of s7 300 plc program with factory io. how to connect. plcsim 5 doesnot have option of s7 300 ..:
1,047
Hi I want to read degree from absolute encoder 1024 binary by plc s7300. Please Describes the functionality of the absolute encoder 1024 binary...
4,414
I have got a PLC S7-300 communicating to a device running Profinet IO. I have a shared data block (DB1) with few attributes. I want to know the...
1,930
dear sir we have 840d cnc with s7300 plc. Can you give me some information about Transfer procedure of Auxiliary H function "CNC to PLC"
2,442
Hi All, I have a simple question about PLC siemens S7300 CPU315-2PN/DP and I would be grateful if you could help me. In which way I can get a...
2,626
