PLC Siemens S7300 clock 30 seconds
awnet
Jun 2007
Viareggio
44
Hi All,
I have a simple question about PLC siemens S7300 CPU315-2PN/DP and I would be grateful if you could help me. In which way I can get a clock of 30 sec to use as a trigger event on my HMI ?
Thanks All.
Hi All,
Thanks All.
Aha! No timers left?
In OB1 you get the CPU clock in the temp-area. Compare sec. counter for 1 and 31. Voila, you've got an 1 sec duration pulse every 30 sec.
Kalle
Another alternative is to use an IEC timer, SFC 4 TON with a preset of 30,000. use the output of the timer to reset itself to make a rolling timer
Can anyone of u help me how to wire a plc i am having a power supply unit ,plc and analog input unit with me i am not sure about any wiring plan...
2,332
Hi, l would like to find out if the above mentioned cable can work with windows vista ultimate and business.How much does this adapter cost.Find...
2,746
Hi all, Does any body have some literature on how to scale the analog input signals e.g level tank control using a pressure...
6,255
hi Iam using s7300plc communicate with mm440 drive. the communicate with each other but some data are not comming in hmi(current )iam sending the...
3,132
