RSLogix 500 Data logging while using Emulator
brar47
Apr 2015
Edmonton
Hello My name is Harry and i am fixing some program for a client.
He has Micrologix 1100 controller and i am using RSLogix 500.
I do not have the micrologix 1100 plc available so i am just using emulator to check my program. Problem is i do not know who to see if values are being data logged properly or not.
Is there a way to be able to have data logging functional while using emulator to run the program?
Thank you guys
sir iam using rslogix500 and rsview32. i want to know the way to set odbc driver and script for data loging and reporting and viewing in pdf format by one click
Welcome to the Forum, Chotu !
I've seen your posts scattered through a bunch of other threads this morning so I wanted to give you a hint about how the Forum works.
If you want to ask a new question, you need to create a new thread. Include as much information as you can about your project and what you've already tried and what specific information you want the community's help with.
To create a new thread, start at the top level of the Q&A section:
http://www.plctalk.net/qanda/forumdisplay.php?f=2
And click the "Start a New Thread" button, which looks like this:
Edit: Looks like you figured it out. Post as much information as you can about what you've already done; not many users are interested in explaining a complex process from scratch.
http://www.plctalk.net/qanda/showthread.php?t=95055
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,669
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
873
I stumbled onto this behavior the other day, then went looking for old forum posts with the assumption that "there is nothing new under the...
792
Hello All, I am working on converting a program written in RSLogix 500 to Connected Components Workbench. The MicroLogix to Micro800 converter...
1,226
I'm working with a customer to copy one of the machines they designed in-house several years ago. The previous PLC programmer had a thing for...
2,117
