Transferring data from RSLogix 500 to Studio 5000
Jun 2023
Ohio
I have a micrologix 1100 that I am trying to read three data points from it on my safety plc using studio 5000. Any tips or guidance is appreciated.
Different ways to do this. Look into MSG instructions and Produced/Consumed tags. If the data you want to share is physical io, you could even consider wiring directly from one PLC output to other Plc input
welcome to the forum.
i would copy the inputs into a bit file and use messages to get the data.
Yes, you can wire directly, but you must pay attention to the wiring neutral, panel power sources, grounding, use yellow or orange wire to designate external power wiring interface, and label the control panel with placard indication external power when the main disconnect is off. its been a while since i did this, so the rules may have changed. look at nfpa 79 - electrical standard for industrial machinery. other codes may apply.
james
Unless I'm not aware of a newer feature, the ML1100 doesn't support produce/consumed tags. You'll have to use explicit messaging. It's really not a big deal.Use a SLC typed read MSG instruction to get data from the ML1100. The path will vary depending on your source PLC type.
Hi all, I'm using a SD card to log data on my Panelview plus and FT View ME 6.0. The old data is overwritten with the new data for every 300,000...
2,869
Hi all, I need to work with recipes. So I have to transfer the recipe data records from storage medium of TP177B to S7 226 plc. When I use "Set...
4,078
I'm tring to understand how discrete info is being communicated between two AB PLC 5's on the DataHwy. The data is in an output file (O:31)of the...
8,278
Hi! I´m totally new to S7 and have the following problem: From a custom-GUI I need to transfer some data between a PC (with Step7-Software)...
4,162
Hi, I am wondering about transferring RS Logix 500 & 5000, as well as Rslinx to a new laptop. The one I currently use in the field is ancient. I...
693
