RSLinx crashes with trying to connect to SLC, deleting Harmony files not helping
defcon.klaxon
Feb 2015
Far NorCal
616
Hi guys,
Working on one of my client's systems with SLC processors, earlier today she called me and said she was having comms errors, had a solid red FAULT and flashing green ENET. I had her do the whole short VBB to GND procedure, and I reassigned its IP address in BOOTP/DHCP Server tool.
However, now whenever I try to download the program Logix500 crashes. Similarly, if I try to click on it in RSLinx, that crashes too. I've tried the whole delete Harmony files trick but that has not fixed the situation. Furthermore, new Harmony files are not being created (the folder remains empty).
Not sure what to do now, would appreciate any suggestions. Thanks!
Solid red FAULT is unambiguously an unrecoverable hardware failure, but it's good that clearing the memory allowed the controller's OS to come back up and run DHCP.
Maybe try running RSLinx "as Administrator" ? Or do a reinstall with Administrator credentials.
Versions?
Any error messages?
Logix500 is version 9.00.00, RSLinx is 3.60.00; the error message simply states that RSLinx Classic Communications Server has stopped working; it's a Windows pop up and it happens as soon as I click on the icon of the PLC I'm trying to bring back.
Solid red FAULT being unrecoverable hardware failure is what I've seen in other threads discussing similar; does that portend that hardware equipment needs to be replaced? I've also read that the power supplies can be responsible.
Did try that, both with RSLinx and Logix500 and no improvement.
I am downloading Logix500 and RSLinx, maybe upgrading RSLinx could solve the problem.
Hey guys, I think I found my problem. I was deleting Harmony files in the wrong folder. When I searched for them, for some reason the files that showed up were not in the RSCommon folder. Why/how, I don't know but I think that's why RSLinx wasn't acting like I expected. Thanks for the help, and if there is anything still unresolved I'll post on Monday morning.
I added several topics to an RSLinx Classic Professional (3.70) installation and was unable to add tags from the topics to Historian SE in...
1,797
I had an interesting problem at a customer's site today. He has RSLinx Classic Professional version 2.50.00.20, and is using the Ethernet/IP...
13,910
I don't have a whole lot of experience with RSLinx Enterprise or I guess it's also called FactoryTalk Linx. We have a Rockwell FTView SE based...
49
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
80
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
230
