RM9600E-460 Radio Modem to Wonderware Archestra
So I’m a little confused as to what you are looking to do. The modems you have are a serial communications type modem and should pass any asynchronous serial data as long as the format matches what the radio will do and is configured for. The protocol will depend on what equipment is using the modems. What is connected to the other modem (or modems)?
Guys, I just started a new job at a company in Charlotte NC that has been here for many years. The transformer feeding part of the plant is an old...
6,464
Anyone have Error 460 on PanelView 1000 2711-K10C8X before? Fault occured. Error = 460.
2,640
I have an automation Panel with simatic S400 PLC modules with CPU 412-2,DI ,DO,AI,AO modules and 3 racks that are connect with each other by IM...
1,563
I have a system that has 4 takeaway conveyors.Each one feeds the next. The first three motors are 460 running at 60 hertz. The last one is 230...
4,316
Are motor companies using a new math to calculate HP? :confused:
5,432
