460 volt Delta Issues, Please help
Dick,
NEC Article 250.20 requires all AC premise wiring systems to be grounded, EXCEPT as denoted in 250.21. Then 250.21.A.1-4 list specific cases where they CAN be ungrounded, but then 250.21.B says IF you do that, you must add a "ground detection system" at the service point and use specific signage (which nobody does). The Ground Detection System will cost you more than just corner-grounding the transformer.
But as you know, in VFD world a corner grounded delta system might as well be ungrounded as far as the VFD is concerned, so be careful about recommending that. I just use the argument to get people to stop using UNGROUNDED delta and switch to (or create) a wye system if they are going to have any power electronics.
Anyone have Error 460 on PanelView 1000 2711-K10C8X before? Fault occured. Error = 460.
2,641
Hi All. The site has got an existing radio RM9600E-460 radio modem. It has a RS232 and RS485 port. But what is the protocol ? Now I wanted to...
2,217
I have an automation Panel with simatic S400 PLC modules with CPU 412-2,DI ,DO,AI,AO modules and 3 racks that are connect with each other by IM...
1,564
I have a system that has 4 takeaway conveyors.Each one feeds the next. The first three motors are 460 running at 60 hertz. The last one is 230...
4,317
Are motor companies using a new math to calculate HP? :confused:
5,433
