Registration users wwalmdb
Silent1337
Apr 2021
Russia
Good afternoon!
Such a problem:
There is a project, authorization works through the Archestra IDE. Platform 2012.
It is necessary that when the user is logged in, the data about him is entered in the wwalmdb database and displayed as an event.
For example:
Pupkin I. I. logged in. Pupkin I. I.
logged out
. How do I implement this in Archestra IDE?
I haven't tested this but I think it should work. There's probably other better ways to do this that one of the Intouch gurus can suggest... i haven't done much with it for many years now.
Create a tag called LoggedInUser or something like that. In the tag definition select to log events.
Then set up a data change script in Intouch, using the system tag $Operator as the data change tag. Assign $Operator to LoggedInUser tag in the script body.
You won't be able to have the text exactly as you wanted saying logged in / logged out but you will be able to track which user logs in and when they log out.
Hello all, I am trying to register a directory full of EDS files using the EDS Hardware Installation tool. But at 7% I am getting a weird...
2,000
Attached is a sketch of our latest project, it's a retro fit of a Hudson Sharp bag machine. It's basically a rotary knife (perforator) in this...
25
8,384
I just upgraded to V32 in order to take advantage of the new safety CPUs of the 5069 series IO. Unfortunately, none of the basic safety IO...
2,869
Hello all, About every 3 or 4 months a Kinetix 5500 drive stops recognizing the registration event signal on input 2, even though you can see the...
3,472
Hello One thing I want to ask is. I have been using the panelview plus 600, but I have seen that it is possible to read it in version 7 or later...
1,252
