Logix 5000 v32 EDS Registration Issue
DamianInRochester
Jan 2011
Rochester NY
1,292
I just upgraded to V32 in order to take advantage of the new safety CPUs of the 5069 series IO. Unfortunately, none of the basic safety IO modules are showing up as registered devices.
Using Linx, I uploaded the modules from the 5069-IB8S and 5069-OBV8S and then used the EDS installation tool in RSLogix to install them. The whole process appeared to go well, and it seemed to be registering them, but then when I go back to the IO tree they are still not available.
Rebooting logix did not help.
Anyone else experience this issue?
Mn5Z9CX
Ok, I finally have everything showing up in the IO tree and it seems to be operating properly. Thank you everyone for your help. Next step is to figure out why my Rockwell USB driver no longer works after the update.
It would be nice to explain to other readers how you managed to fix the profie issue.
Since you did not post solution, AOP for both modules is available for download.
AOP for some newer modules must be installed separately, they are not part of Studio 5000 install.
Can ping module and shows up in Hardware config with no faults and shows "running" in status. Can read inputs from the FEN20_16DXP. LEDs on module...
1,651
Hello, I am trying to export some add on instructions & sub routines and import them into a program that is in Rslogix 5000 v20. The program...
1,774
Hello everyone! Question is basically in the title. I have a version of Studio 5000 Logix Designer V32.00.00 but I need the V32.00.01 for a...
2,982
I'm very new to PLC programming and need help setting up a communication path. i would appreciate it if someone could please explain to me how to...
5,874
