Quantum 140 CPU 651 60S Controller Restart Time!
jawad rasool
Feb 2012
Lahore
51
Hi all,
Yesterday I tried to reset the Quantum 140CPU65160S controller by pressing the Reset button available on front panel under the cover.
The controller started it diagnostics and memory check, then there was a message "Controller Initializing, Please Wait" this message was there for about 20 minutes but the controller didn't boot up.
Then we turned the power OFF and again turned the power ON, this action started the controller.
Please confirm if this long duration while reseting the controller is normal?
No that is not normal.
Is this a unity based processor or are you running concept? Suggest you attempt to go online while the processor is in this initializing state and see if the diagnostics in the programming software gives any further clues as to what's going on.
I need Help !!!!! We are having Schneider Quantum 140 CPU 113 03 working in redundant mode, installed in 2006. I have no backup or Schneider...
2,271
Hi, I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The...
4,546
Problem with Quantum 140CPU11303. I've been unable to connect with programming terminal and the panelmate cannot connect. This system has been...
6,928
Hi Every one 1) I am using Quantum CPU 140 434 12A, Which has got two modbus comm ports,with XXMIT EFB and RS-232, i successfully communicate to...
5,134
Hi, First of all, thanks in advance for those who support and advises. I have a Modbus/TCP operational network as shown below. However, at any...
912
