I have new Moodicon PLC CPU 140 652 60 and I want to change the IP address, Subnet mask, and the gateway for this plc using the key pad. The manual said the following:
1- Parameters can be modified only if no applications have been downloaded (in NO CONF state).
2- When a new PLC application has been downloaded, the Ethernet address on the screen is only updated after accessing the highest level of the menu structure.
I downloaded a new PLC application means I need to go with option 2. How I can access the highest level of the menu structure and change the IP, etc..
Thank you
Thank you
