Prosoft MVI69E-MBTCP - Config help
lostcontrol
May 2009
NeverSayNever
1,071
We have an application that has a device that goes through a reboot (appears un-graceful)
What then happens is the MVI module appears to hang & comms are stopped.
Issuing a warm boot seems to recover this, so am doing it automatically. Unfortunately, this has some minor issues that we are working through.
What we want to know, is there a way to disable the read commands in PCB via ladder command.?
There is MBTCP.CONTROL.CommandControl.Trigger in the manual, but it is not clear whether this relates to the PCB configured commands or dynamic commands that can be created.
any help/tips appreciated
lc
I have an application where I need to communicate via modbus with a Mitsubishi PLC. My PLC is a CompactLogix L33ER. The Mitsubishi is the client...
2,507
hi I would like to know if somebody already try to implement specific communication protocol thru MVI69E-LDM (from prosoft) to be able to...
1,545
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
116
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
299
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
442
