Programming cable option for fx2n
efratalove
Mar 2024
adis abeba
Dear all,
I have fx2n plc on my hand but I don't have the programming cable sc-09 and it would not be easy for me to get one. I need the cable only for loading ladder from pc. I am considering two options
1. Making the programming cable. There are a lot of website and YouTube video who show how to make the programming cable with port connector and resistor. But as far as I know the plc port is rs422 and pc rs232 how could that be possible?
2. I have rs485 to usb convertor. Is that possible to use this how could the wiring be? The plc port is rs422 is that okay? What about full or half duplex issues?
3. Probably I could find rs422 to rs232 convertor on the market. What about this option?
Please let me know Advantage and disadvantages of the three options
The SC-09 is an RS422 to RS232 converter, I've just checked mine.
It's two cables, 8-pin mini-DIN to 25-pin D-sub RS422 cable, then 24-pin to 9-pin D-sub on the RS422 to RS232 converter. As far as I can tell, this is just a standard cable that you should be able to get or make from anywhere.
Ebay have some I have never used them but apparently they work from what I have heard, make sure it's one with either the mini 8 pin or with an adapter from 25 pin to 8 pin mini.
I have seen the resistor bodge a few times on the net but never fancied trying it. providing you can get the driver (com port) for the USB type clone cables I have no idea if those clones use the USB driver or perhaps a virtual com port.
Just be aware if you do manage to get the SC09 cable & you have no 232 com port then use a usb to 232 converter providing (if you have win10/11) make sure the usb/232 driver has the latest chipset i.e. PL2303 (I have a UGREEN one from Amazon & it works well.
Hi Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need...
172
1203-USB I can't find it for sale new so I assume it's no longer made? Used, folks want no less than $1k USD for it missing all the cables and in...
2,080
Hey Guys I am trying to figure out the correct cable to use to connect from my laptop to this Panelview using panelbuilder32. I was sure I had...
2,048
I need to emergency fabricate a cable to program a Parker 690+ VFD. Part # CM351909 I believe. RJ6 on one end, DB9 on the other. I cannot find the...
2,303
Do the Horner adapter RS 232 to snp adapter could work on that plc to go online with my laptop and Proficy ? HE693SNP232A with a IC200CBL001A I...
1,983
