Schneider plc SR2A201BD programming cable
swissi
Nov 2016
libya
Hi
Please I have zeilo smart relay #SR2A201BD but I don't have it's programming cable. Can I use any general usb/rs232 converter? Or need rs232/ttl converter? Or schneider cable should be used? Really appreciate your support. Regards
It takes a special cable due to the funky connector on the Zelio end, and it appears that it is obsolete and everyone has figured out what they're worth which is apparently around $150.
SR2CBL01 is the cable part number. At that price, I would at least look for the pinout and the availability of whatever that male end is.
But, the 9 pin end appears to be normal RS232 that should work with a good quality USB to serial adapter.
One of my coworkers had to get one a couple of years ago and as far as I know, he used it with his USB/232 adapter from plccable.com unless he got the USB variety:
Hi
Thanks for the reply.
I had tried with an other usb/rs232 converter, settings are 115200, 7, E, 1..... but got error while trying to connect on zeilo soft. Error says plc not reacting.
Am I doing something wrong?
Regards
If you don't have the cable, why would you look for the serial version, is SR2USB01 not the same thing with usb or am I missing something.
There also was a bluetooth version too, SR2BTC01 but that was expensive.
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
139
Trying to identify the Modbus RTU registers that are in use in the Function block programming in the PLC program. I have a Kohler DEC 550...
165
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
348
Hi All, We are planning Establish communication between Power Energy Meter (Schneider PM5320) with Rockwell PLC. I am unable to get the Assembly...
766
so i have an isssue where if the serial port of an M340 plc disconnect from the screen it would retain the values of the variables being sent...
919
