PLC for home automation?
antor
Apr 2006
NA
Hi, I live in Europe and the home automation protocols available here (x10) are not reliable and the more robust one (Insteon) is not available yet.
I am building my new house and I'd like to use a PLC to control everything, from lighting to heaters, etc.
I am looking at the Omron CPM2A in its AC powered relay outputs configuration (CPMA2A-60CDR-A) but the switching current is limited to 2A @ 240V, which roughly means ~500W. I may have outlets which would need more (e.g. heater, computers, etc.) - I am thinking on getting external relays supporting more current for those.
Any suggestions for relays? Any suggestions other than the Omron?
1) On the PLC, Personally I'd go for a AutomationDirect DL-06. However I dont know how it compaires to the Omron your looking at, or if it's available to you in Spain. I do know the DL-06 has lots of features, costs about $220.00 USD, and has a short learning curve.
2) The relays: I would use seperate relays driven by the PLC outputs. They will be easier and cheaper to replace when the time comes. I would not use solid state relays due to the leakage current issue. Some of your appliances may not react well to this.
Cbus?
Clipsal make a product called CBus which is designed for this application. I am not a salesman, and am a fan of PLC's over most other control methods, but for this type of application, where the control is very basic, then CBus is a decent solution, the only thing would be the cost as opposed to a PLC. But wiring and installation costs are different, than with a PLC.
check out www.clipsal.com/cis for information. I know this product is available in the UK, and more than likely spain also.
This product has advanced from when I first got involved with it in its early days, and is some neat products out there. Seriously worth considering, but again, the hardware cost will possibly be the decider.
Configuring the system is not that difficult, if you have an understanding of network configurations and bus type systems, then it shouldn't take you long to get up to speed.
when i built my new home two years ago i consided whether to use a plc or clipsal cbus
in terms of hardware costs the io is more expensive
as i am an electricain and programmer i could do all the work myself
all switches and control racks are looped with cat5 cable using some form of serial comms
this makes the control wiring easy
one big reason i chose a commercial product like cbus
was with a plc if you go to sell the house it would be one of very few houses with a plc as there is many house's with cbus
you now link wireless devices to it
Great pointer! Thanks!Could you recommend suitable relays for the DL-06 unit?
Regards,
Andres
Anton, how about European Installation Bus (EIB)? It's about the most robust system I've heard about and it's supported by over 200 different manufacturers now.
Kind regards,
About how much more is a cbus unit as compared to a plc, pretty hard comparison to make i know but just take a stab at i
Not sure on that one, the biggest difference between using a PLC and CBus, is that Cbus is a network based system, so you need to buy units to install your network. There is input units, output units, bridging units, touchscreens etc, and now, as surfer stated, they have wireless options also, I think the wireless option is the way they intend to retrofit to existing installations.
So depending on the no. of circuits, is how you would design and hence, price your installation, whether you want standard relays, or dimmers, or high power dimmers etc
There is also the possibility to link into hifi equipment via serial comms.
it all depends on what you want to do if you just want to turn a few lights or water features on at certain times then a basic plc like the automation 06 or omron cpm2a etc
if you want dimming then you need analoge cards etc dimmer sytems
where as say cbus systems talk via coms
the full extent a a cbus style system is if say youre in your home theater sound up very lound and some one comes to the door then the system can change the tv to door camera turn the sound down swap to the door speaker turn the lights back up etc but costs a lot of money
i havent gone to those lenght,s
About how much more is a cbus unit as compared to a plc, pretty hard comparison to make i know but just take a stab at it.
I recently looked at CBUS for a Builder mate of mine, he was quoting a 7 bedroom medium to large house for about 750k AUD, to go with the top of the range CBUS it added an extra 15-20k AUD to total, this include all the mod-cons CBUS has to offer.
I think the client is impressed by the product, but not by the price, cheap skate ;)
Kind regards,
Hi - Can you point to a ecommerce store that distributes EIB products? My setup would be basic, and this is why I'm inclined to go to a PLC device.
Rgs - Andres
Silly question
What are you going to Automate in your house?
I have only last year finished my house and it never occured to me to automate it.
Hi all, Has any one of you used PLCs for home automation sort of projects? There`s a large commercial building essentially looking to give us a...
22
7,901
Hi All, I have been searching through post to post trying to find answers to some questions I have. But somehow I believe I am going round in...
15,490
Hello, Can anyone tell me how can I dim the lights with a PLC (maybe external relays, but which ones?), I'm doing some home automation and this...
20
11,628
Hey there fellow PLC'ers, I use GE 90-70's and 90-30's currently at work and I've used Johnson Controls controllers in the past so I'm familiar...
9,059
I'm looking for some starter kits but there aren't so many on the market, so I'm thinking about buying individual components for my needs. I just...
2,529
