PanelView 5310 and remote module Flexy
Althalusss
Nov 2023
City
Hello,
I presently have a Allen Bradley PanelView 5310 at a client site and i can access to the PLC/HMI local network with a remote module Flexy 205.
The problem is that each time i try to download into the HMI, i got the following error. It seem to establish communication with the HMI but the problem occur when it download the project.
What i dont understand is that i can ping the PLC and HMI. I also see both equipment online in RsLink Classic.
Is there some parameter in RsLink or Studio 5000 View Designer that need to be set?
Thanks for your help
I had a similar problem downloading to a PanelView 5310 over a remote network connection. It worked well when I was in the shop, or when I was connected over a VPN from a hotel a few miles from the shop. But when I tried to download from across the Atlantic it failed.
My ControlLogix on the same link was very slow, but could download and upload successfully.
So my conclusion is that the PanelView 5310 must have some shorter timeout values that are non-adjustable.
My workaround was to e-mail *.VPDR runtime files to a technician onsite, who loaded them using the System menu screens and a USB drive.
Thanks Ken for the information.
My client is around 2 hour from my office but if they limit the internet speed at the site, maybe thats why i got that problem.
I can connect to the PLC but like you said, its really slow.
In a PV 5310, can you format a numeric object to create comma's in the thousands position? I see no way from the properties panel.
488
I am using a panelview 5310 with a compact logix 5069-l306er. Studio 5000. when ever a security code is entered i would like to know that security...
3,212
Does anyone know how to synchronise the time between these two? I had thought that the HMI could write a LINT (time/date in microsecronds) to the...
2,241
I am learning how to use the View Designer software. I have worked with FactoryTalk View ME and SE but this is quite a bit different. I have...
2,727
113
