Panelview 5310 - Format numbers with commas
It's a PV5310.
Axis position and Cycle time are Real's. Cycle timer is that timers .acc, Dint.
This is all you get with the numeric display.
I haven't seen anything like that, it only reads the tag value. I also convert Dint's to Real's, in most instances, so it displays properly.
I wish they let me use a Red Lion Graphite on this.
It's kinda funny, but I told a guy there that if I used a Red Lion on this, life would be easier.
So now, every time I curse, he yells out you should have used a Red Lion.
Hehe, funny! Every time our fridge messes up in another stupid way, my wife can predict that I'll just say, "Sigh...Samsung". It's become a running joke that's not very funny...
One way I have done it in the past is making the numeric display, then adding a (separate) text box with a comma where it needs to go. Then add a visibility to the comma for only being a value over 1000. You'll need to be careful with the text alignment. If I remember right, it will need to be right justification...
Ok, that's pretty clever. Its **** that its necessary... but that's a good enough workaround for now. Thanks.
I was leaning toward something like this as well, but it could be ugly as you really don't get the space the between digits the comma takes up.
You could probably rip the value apart into 3 separate numeric values and poke a visible comma where necessary, but that's a bit of work.
I don't have a processor here, so can't play with it. I didn't see any other conversion instructions in Logix that could possibly do this, but there may be?.
Hello, I presently have a Allen Bradley PanelView 5310 at a client site and i can access to the PLC/HMI local network with a remote module...
114
I am using a panelview 5310 with a compact logix 5069-l306er. Studio 5000. when ever a security code is entered i would like to know that security...
3,208
Does anyone know how to synchronise the time between these two? I had thought that the HMI could write a LINT (time/date in microsecronds) to the...
2,239
I am learning how to use the View Designer software. I have worked with FactoryTalk View ME and SE but this is quite a bit different. I have...
2,725
I've adjusted the IP of the Panelview Plus as well as the DNS servers; the screen does not show up in the search when I go to the transfer utility...
105
