Modbus TCP connection problem
hoejinkim
Aug 2012
Oregon state
23
Dear experts
I have a great problem in terms of connection between PLC and vision software through Modbus TCP.
Roborealm (vision software) is Modbus slave and provide module for Modbus TCP/IP.(first attached picture)
For PLC which is Client, Ethernet cable is used between ECOM module and Direct Soft5.
Ladder logic is programmed based on the manual(hexcomm).(second attached picture).
what i am gonna go is that when vision software inspects a part, it send the part number to PLC. My question is variable setting(second picture) in vision software, there are table, address, and so on..., i am sure port is 502, slave id is 1 getting from peer to peer module in Netedit. but i don't know about table address....
another question is a programming of ladder logic. is that second picture right? when the PLC receives a variable from slave, how can i check it in PLC?
thank you.
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
359
Hello, I'm gonna try to make this as clear as possible. For a project, we have 3 Unitronics PLC's controlling each a machine. The company that...
3,465
Hellow, I would like to build a MODBUS TCP connection between a Siemens CP443-1 (or a Siemens CP343-1) card and Visual Basic Application on...
12,669
I have a new 1211C to play with so I decided to test its Modbus TCP instruction. I have followed the guide below but it seems that I can't...
3,607
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
362
