S7-1200 Modbus TCP no connection
kallileo
Jun 2008
Thessaloniki, Macedonia, Hellas
353
I have a new 1211C to play with so I decided to test its Modbus TCP instruction.
I have followed the guide below but it seems that I can't establish connection.
https://www.dmcinfo.com/latest-thinking/blog/id/8869/using-an-s7-1200-plc-as-a-modbus-tcp-slave
I don't have a hardware client so use software modbus TCP client emulators like http://www.simplymodbus.ca/TCPclient.htm
http://www.modbustools.com/modbus_poll.html
I can download my program to the PLC but I have no connection through Modbus TCP.
What could be the problem?
I've never used this type of controller before, but I have used Modbus TCP/IP. I do know through my experience that choosing the right port could have an impact whether or not you are going to communicate. If this controller has that option.
can i send and recieve data using my yokogawa UT35A controller with my siemens s7 1200 plc using profinet communication without using gsd file
421
Hello All I have a modbus tcp device(Julabo magio) with an DB9 pin assignment. Pin3=B and Pin8=A. I would like to connect it on the secondary...
1,647
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,969
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,537
Hi, I currently have a s7-1200 enabled as modbus tcp slave for customers master to connect to freely. Now my customer want to add a new modbus...
4,707
