Maybe a dumb question about meter leads?
PurpleSquish
Mar 2024
Welcome1!
Hello folks! Never been here before but I have a question that's been bugging me for a while. I recently got a job at a chemical plant that's been around for quite a while. Long story short is there hasn't always been a norm for electrical diagrams. It's an absolute rat's nest of pipes and conduit everywhere and we normally deal with instruments/solenoids and the like controlled or transmitting to PLC's. I've always wondered when we don't know where something connects in the field (which can be quite frequent) why we don't just get like 1/8 mile of wire and ohm it out with a meter. Is there something wrong with my thinking? Thanks for any insight!
Me, too. I've got about 95 feet of 14-3 former 100 foot extension cord (that got cut at one point) with insulated alligator clips on all the conductors, but there's a limit to dragging cable around and dealing with the Safety Officer that wants the cord crossing the walkway to be taped down and a saw horse with a sign put over it so no one trips over it.
Old timers would use a pair of telephone handsets with batteries strapped on for power with one known wire connected between them. Alligator clips would be connected to the end of one wire and the other end, often even in another building, connected to each wire in the conduit in succession. When a match was made the phone would ring. This process was referred to as ringing out the wiring.
I always wondered where 'ringing out' came from. Awesome, thanks
Done that several days no more than some 20 years ago with older coworker. We did cable ploughing and all wire joints needed to check functionality afterwards between several kilometers. Handsets were probably from somewhere 60's or 70's. It needed only three wires. Nice design and it still worked well. It had earmuffs and mic and we could speak each other when tested other wires.
most companies have radios for maintenance, requires two people but just get one at each end then short each cable in turn to either ground or to another designated cable did this for years, until I built myself a 16 wire system with led's connect the transmitter to one end & the reciever to the other, normally only used one or two channels each had a different flash rate I used cmos digital ic's to generate the pulses did not use it much as there was normally one other engineer availlable to do the testing.
can I use a mov instruction to move a 0 into a boolean data type? I dont have a way to test it right now and I never tried this.
3,091
Hello! The equipment I'm working on uses a lot of indexed tags I guess you'd call them. I thought it was indirect addresses maybe but all the...
1,053
Hello all. I have 5 PF525's in my RSL5k project. One such drive I am able to ping and it responds. The Enet on the front is steady green and the...
2,845
I have come across a situation that could be in need of help. Presently, they have an L71 running version 24.12, and they want to revise it...
1,342
Hello, I've had a 1746-NT8 thermocouple input card fail on an SLC5/05 unit. There is another TC card in this rack that has spare input channels...
1,642
