rslogix5000 question. maybe dumb.
diat150
Mar 2006
Louisiana
1,476
can I use a mov instruction to move a 0 into a boolean data type? I dont have a way to test it right now and I never tried this.
It won't work. The Rslogix compilier that you are moving a DINT into a BOOL and give a parameter type mismatch error
ok here is the scenario. I am looking at some data from a different device via wonderware. wonderware is setup to toggle a boolean data type register "on" in the plc when I have a alarm state on that device. the policy is that wonderware will only toggle the bit high, not toggle it back to zero. I need to figure out a way to toggle that bit back to zero after the plc scans that routine which would register my first out alarm.
I know that I can do this if i have wonderware write a integer to a register and then do a greater than which would then set the bit. then I can move a zero back into that register at the end of the scan. I may end up having to do that depending on what the wonderware guy does.
do I have any options to toggle that boolean bit back to zero another way, without using a integer?
CroCop said:
Yes, the instruction is OTU. That's all you need.
ok would it be setup like this
---[bit]------------------(bit)latch
---[bit]-------------------(bit)unlatch
where all of the bits are the same?
or would I just need to do this at the end of my routine and not worry about the latch?
----[bit]------------(bit)unlatch
excuse my ignorance on this. we never use latch or unlatch in our programs.
Without seeing your application, I can not comment on the logic nessecary for correct operation.
The OTU instruction will write a 0 to the bit level. Read in the help file if that isn't clear enough.
I've got a question for those of you with Ignition experience: I've been interested in Ignition for a few years now, have not had a chance to use...
1,902
Hello, Question: (Temp is whats being controlled here by 3 fans) Using a PID; can I set my output (CV) to be 100% at a specific input (PV)? In...
2,256
I did a new installation of RSLogix 5000. When I open a project if you look on the tree to the left, if I double-click the "Controller tags" a new...
1,793
i'm testing project using the emulator. i setup communication on FTV studio and configured connections with the right tags but when i go test it...
2,044
Hello everyone. My first tread. I am not a big specialist with PLC, but I have some experience, a little. For our new project we have two...
2,208
