Is the time right for a commercial PLC Programming Tool that runs on linux?
OK, that makes perfect sense indeed, I had not understood that correctly. My apologies.
I have not needed this myself so no detailed first hand knowledge here, but if I understood correctly then Wago has PLC hardware running Linux that you can work from yourself in software running on the OS in the controller. Programming in i.e. C/C++. You may want to look into that path, as you can use your choice of approved Wago modular I/O's.
E.g.
http://global.wago.com/en/products/new-items/overview/basic-page-2600.jsp
http://www.wago.us/products/compone...tem-ip-20-750753-series/plc/linux/index-2.jsp
Thanks, will look into that. Have been seeing Wago products in a lot of the trade magazines lately.
See the Codesys LD program below; I would expect Rungs 2 and 3 to produce functionally identical results, but they do not. Does anyone have any...
36
2,096
Hi All, I have a programming background but have never used a PLC. I have what I think is a simple automation project however Im not sure of the...
19
1,904
Hi All, I'm new to Siemens PLCs. I have a device that have a Siemens 1515SC IPC ruining the control and HMI applications, its documentation...
1,751
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,926
