Is a PLC the right tool for the job?
You are asking for advice from a bunch of hammers in this forum, so this project certainly looks like a nail.
Literally what I was thinking!
I've done lots of automation around arduino and similar devices. Not everything needs to run for 15 years on the factory floor or on an oil rig. That said, I have built arduino-based devices that run on large machine tools.
OP: If you're a programmer, then C/C++/Python on an arduino or clone is probably easier for you than PLC ladder logic. If needed, there are ruggedized versions with isolated inputs and high current/relay outputs.
This really isn't a good forum for this kind of discussion so if you'd like to probe further, send me a Private Message and we can talk about what I can build for you, or if you prefer, I'll offer suggestions for DIY.
If this is for fun and you have C/C++ experience, then an Arduino will fit the bill.
If it does need a lot of reliability, replication, or sale to others, I would find a simple mobile machine controller from someone like ifm or TTC. These will generally allow you to use Codesys or C and will interface with mobile equipment better than an industrial PLC. They can be a bit more of a pain to work with due to often needing a harness, but for a product that is to be sold to something in that environment, they are the better solution and require no enclosure.
With Windows 7 End of Extended Support being just under 3 years away (Jan 2020), is the time right for someone like Inductive...
45
13,155
Good Day everyone, i am currently wiring up a panel and i am not sure if a L36ERMS compact guardlogix controller is just used for safety or you...
570
Good day all. I work for a small company that would like to start automating the production of our goods. I have been tasked with doing some...
49
13,554
Could someone point me to a DB9F right angle cable that would allow me to close the door on a L61 PLC? Certainly one exists but all I can locate...
1,788
Hi all , I am a student working on my first PLC project . My project is to automate a mobile water purifier .the water purifier consist of 2...
1,779
